As many of you are familiar with my Picasa pictorial of EHCS overhaul https://picasaweb.google.com/pozoizquierdo/HYDRAULICCENTERSTANDOVERHAUL#
I wanted to inform you that I added some pictures which I took during my second service 2,5 years later from the original one. I realized that the centerstand was no longer working as well as it did before.
As added items I also took apart and cleaned the actuator rod seals as well as the pressure valve. I also decided to put in a new electric motor and there is also the motor purchasing instructions in the picture text.
Regards
Great Job documenting this Ari. Look forward to seeing you again at CCR.
Hi Ari,
Thanks for the pics and the rebuild information. I am at this point and this will save me a lot of money. If you have an oportunity South Africa is the country to tour.
Regards
Thanks Ari,
This was a great help and a big $$$ saver for me.
My center stand started acting up and withing a week it died. I took it off the bike and as a first thing I removed the electric motor. This thing didn't work even with external power, so I took it apart and noticed that one of the brushes was broken in half and there was a lot of oily black stuff in the commutator area.
I didn't see an easy way to fix the motor, so I took your advise and purchased a new one from the site that you provided the link.
I did the shortcut and did not take apart the hydraulic pump, just drained it, flushed and filled with new oil.
As you suggested when draining it, I poured all of the oil into a measuring flask to make sure that I don't overfill it with new oil.
When adding new oil, I really had a hard time to squeeze that measured oil in - I don't know how is it possible to put more than the measured amount.
Anyway, when the motor arrived, I installed it, checked with external power on the bench and it looked that it worked just fine.
Installed it on the bike and it works like a new - much quieter than before.
It's been about 2 months since then, using it everyday at least 4-6 times a day and so far it's been working great.
Thanks again,
BJ
