1 - 14 of 14 Posts
Hello and good day to all.
I feel vibrations that i never felt before, (2003 BMW K1200LT, with 131000 miles on it) and I believe the drive shaft is on its way out. My questions are to all of you, how complex is it to change the drive shaft? Any special tools needed? any idea on the cost of repairs?
I do appreciate any advices, comments, expertise. Thank you and happy roads!
Jean
All you have to do is pull the rear drive off to get to the drive shaft. Hefty 12 mm Allen, 30 mm socket and a breaker bar to get it off. Slotted 30 mm deep socket to set the locking torque on the adjustable pin. Changed my shaft at 98,000 as I had the drive off and transmission out for a bearing replacement. The u-joints felt a little "notchy". I got my replacement off e-bay years ago from a low mileage bike.
Reactions: kbob12
Just a little suggestion before you begin dismantling. Have you thought about getting your wheel balance checked.
On a scale from 1 to 10 how difficult is it to do! On man job or need help? what challenges may I encounter as I pulled the rear drive out?
Thank you.
Can the U joints be rebuilt?
I noticed a slight "notchy" in mine as well.
Thank you.
A 4 at most I would say.
It is a "no service" drive shaft. Have to replace.
If you want to see what is involved look at Part 1 here Weep Hole Drilling Video
When my final drive went out, I felt a vibration I never felt before....if you’re thinking drive shaft, then I would assume you have checked the final drive fluid for “metal dandruff “ already??
I have a R1200rt that I recently replaced the drive shaft. I would call it a 6 or 7 on scale of 1-10.
I looked at numerous You tubes and went for it. I bought a shaft from Beemer shop in Scotts Valley Ca.
I don't know if they have one for the K1200lt. The shaft is rebuildable that they sell. Mine cost $650
plus some grease torn boot and day and a half of working on it I am very happy with the results.
Prior to starting I called BMW and they wanted $1300 for the shaft and about $800 labor.
Good Luck
beemershop.com
Very good info, thanks !
Still pricey though, but a good option, particularly for those in the States.
Wow, those prices are good!
Shipping, on the other end is what kills us. Almost $100 CAD.
Jean
My guess is final drive... I have parts if you need them..
1 - 14 of 14 Posts
