1 - 2 of 2 Posts
you need to replace the gasket behind the slave cylinder, and 4 x crush washers for your clutch lines, would recommend you change out the seal behind the slave cylinder, I had to change out mine but went through 2 slave cylinders in 2 months to figure out the leak, it just was not that obvious on what was leaking. A relatively simple procedure if you do it enough times.
1 - 2 of 2 Posts
