I have just done a little experiment inspired by something Drone said in reply to something I said in a discussion about ABS problems.
To set it up I poured some fresh Dot 4 into a small plastic container. The amount was 75 mils of Dot 4.
Into that I dropped water at 2 drops per test. The following photos will show the first photo tests as perfect, no moisture.
The second photo will show the dropper used.
The third photo will show the result after the first two drops of water added and it showed 1% but ok.
I took photos every 2 drops of water but I won't bore you with those. The next photo you see will be after 20 drops of water and it indicates a serious problem.
The last photo shows you the comparison visually of the volumes in question.
The actual amounts were as I said, 75 mils of Dot 4 and the water added which is indicated on the dropper by the two black lines is just a little under 1 mil of water.
This little experiment may help in decisions about how long you should potentially go before changing fluids. As you can imagine, the moisture content will play havoc with the internals of master cylinders and ABS units. The other thing you may notice is that from start to finish of the experiment the color of the Dot 4 did not change, it looked as fresh as fluid without moisture.
