Might help in soft ground or just carry a piece of wood?
http://www.ebay.com/itm/BMW-K1200LT...Parts_Accessories&hash=item20c43bc55e&vxp=mtr
Thanks guysK100Dennis said:Yeah, they cause too much loss of lean angle towards the left, you'll scrape the crap out of it when you hit the twisties, especially 2-up. I actually removed as much of the underside of mine as possible with a grinder and cutting wheel. It's possible to increase the surface area by adding more to the top side of the foot when the stand is retracted, just make a cardboard template, ensuring it will clear the centre stand and exhaust etc, then duplicate from 1/8" plate and weld it on. Oh, and you can also trim off approximately 1/2 the rubber bump stop for the side stand, that'll gain you a bit more lean angle.
