The narrow, clear plastic window that covers the radio display has become quite discolored due to the sun. Can it be replaced? If so, is it a big deal to replace it?
Thanks in advance....Phil in Bakersfield
No answer for you here, but mine is also now discolored. Looks like soap spots or something on mine, but I havn't found anything to clear it up yet. Anyone hava some suggestions for us?
You can use NOVUS 1 on it and it will clean it up, #2 will work as well but then go over it with #1. Some have used denatured alchohol as well. It works but can leave the plastic and surrounding plastic slightly melted looking. Use with care and sparingly. The novus product is a plastic cleaner/polisher and won't hurt it at all but does make a difference.
During dry weather, I polish it with a clear plastic polish.
When it starts getting wet, I put a clear packaging tape over it.
Old Slow Guy in A Fast Car
A little denatured alcohol will clear it right up. then cover it with any clear tape to protect it.
Tile-x cleaned mine up 2yrs ago with no harm to the plastic. Then used packaging tape also.
I have had mine discolored whenever it gets wet. I use plexus to clean it off. Works everytine. Just a little dab will do you.
I like the idea of putting tape over it, would help in the rain
Hammer
