1 - 20 of 21 Posts
Well I did it again.... :(
For the first time she went down to the right ... (turning into my driveway... for God country and wife to see) .
My question is the brake pedal was bent.. I adjusted it back with a large pair of channel locks... Is there something else I need to check?
The brakes appear to work fine and other that a bumper scratch and bent pride all is well..
When I bought my bike (used of course) the brake lever was bent...I threw a crescent wrench on it and torqued it back into place and rode it for 850 miles home. never once had a problem with it and now about 12000 miles later ...still fine. If you have deeper pockets than mine you might want to have it looked at. I know mine is fine though. I don't know the damage that yours has had.
Thank you all
I have looked all around and don't see any additional damage..
Is there a trick to lifting the bike on that side? I put the side stand down and got my son to help me right the bike... signaficantly more effort than the other side.
I'm getting good at picking it back up :histerica
I've dropped mine on both sides, and never noticed any real difference in picking it up one way vs the other. The only time it was, the bike was on the right side, but there was a slight downhill slope to the driveway, so I was having to lift it more than 90 degrees. I did have to get some help that time.
The other time it was down on the right, I just put the sidestand down, grabbed the handlebar and the sidecase handle, and walked it back up backwards. The first time I forgot to put the sidestand down. You should have seen me scrambling to get the bike in gear, hold the brake, get the sidestand down, all on a downhill slope.
Now that I think of it, three of the four times I've dropped it, (three times in the first 24 hours I had it.) it went down on the right side. No damage though.
PhantomK12LT said:
3 times in the first 24 hrs? Wow, that must have hurt...
Prolly 'bout as bad as your droppage rate after picking up your scoot in the Northwet and running back to Houston, IIRC. Don't I remember you approaching double digits on the fall-down-go-ouch scale!!! :D ;) I'd say you got it out of your system with that trip!! :histerica
Course I'm not too far behind your count!! No confessions here tho!! :rolleyes: :D
Best.
Naw. A few scratches on one of the sidecases is all. I was able to just step off each time. This bike was a HUGE jump for me. I probably shouldn't have bought it considering that I had never ridden a motorcycle with either a straight drive transmission, or a rear foot brake. That's not even taking into the account the weight or the high center of gravity.
First time. Turning into the driveway on the trip from the dealers to home. I wasn't used to having a rear foot brake. My previous bike (Yamaha Majesty 400) had both brakes on the handlebars. I grabbed the front brake. Boom.
Got it up, and got it to the bottom of the driveway which is one a downhill slope. Got it turned around, and up on the centerstand. Decided to go for a ride a little later and checked the owners manual to make sure how to get the bike off the center stand. The owners manual says to stand beside it, and push it forward. This might work, except (1) I have no real idea how heavy this bike is, and (2) my driveway slopes to the right. (I needed help to get it up that time.) My advice now is to straddle the bike to get it off the center stand.
The third time was the next morning. I rode it to chuch and when I went to leave, I had the front wheel cut too tight, and dropped it when I let the clutch out. Left side this time. I could have gotten it up by myself that time, but there was another guy there who jumped to (1) make sure I was ok, and (2) helped me right it.
The last time was at a gas station. I was approaching the pumps and didn't see a car cutting through the parking lot. A truck was blocking the view, and he didn't see me either. Again I grabbed front brake while turning. I just picked it up and rode it on to the gas pump. I don't think the guy in the car ever knew what happened.
STAY OFF THE FRONT BRAKE WHEN TURNING AT LOW SPEED.
With the bike down on its right side you can also hold the front brake lever with your left hand as you walk it up. However, if you've already put it in gear this won't make much difference.
Anybody picked an LT up solo? It weighs on my mind a bit when I'm riding alone. I recently visited a friend in the Catskills and he 'assigned' me a parking space. I was unpacking the top case when she went down. No damage, just shifted into gear so I know the lever must have touched. But, after a couple of vain attempts to right it alone I realized it wasn't going to happen.
Hey Dale,
I picked up mine solo about two weeks ago. My first drop was in my driveway...a victim of somewhat less than excellent kickstand engineering along with somewhat less than careful operation :eek:
I was able to get the bike back up using the - face away from it, grab the handle and back up very slowly using very small steps method. For me, the scariest part was then transitioning to facing it and putting the kickstand down again coupled with the fear that I would push it too far and have it fall over on the other side..anyone ever done that?
My best advice to future droppers is: Do not try to save it. I was standing right next to it when it began to fall and thought I could stop it. Two bad things happened as a result.
1. I hurt my back in a big way. It's better now, but never having had a back injury before, I did not fully appreciate that particular kind of agony.
2. The driver footpeg, true to it's name pegged my right foot to my driveway. That was a new and significant kind of pain as well. Now I was forced to lift it off my foot, while standing perpendicular to it which did not help my already injured back.
Ugh...the whole time I am thinking, "This can't be happening to me!"
Wow! Sorry to hear that. Fortunately, I was in no position to try to save it, and I certainly would have tried. Good to know that it's possible to pick up alone. Thanks!
Dropped mine only once in the two months I have had it. I was in a rest stop in Illinois and I thought the side stand was "all" the way down. My 05 has a side-stand-bad-habit of only going half-down or half-up. Killed the engine putting the side stand down, but ALL THE WAY DOWN IT WAS NOT.
I immediately approached the car parked next to me to ask the driver if he could help upright the beast. He rolled his window up and locked his door in a flash. I have an affect on people like that, having the beard and long hair and all. He eventually rolled the window down after a few minutes of coaxing. Another guy who was walking by while we were uprighting the beast threw in a hand and all was well. The guy from the car said "That is the biggest motorcycle I have ever seen". I will remember that statement forever.
Just in time as well. Four Harleys pulled up after we got her upright. I am sure they would have had a chuckle seeing me in my predicament.
Who ya' gona' call?
:p
Zotter said:
Not likely to be anything else, so long as the plate is ok.
(guessing, I'm not a BMW certified tech, but I did stay at a Motel 8 last night)
Tate from now on! I have heard that people who stay at the Motel 8 are smarter that the ones who stay at Holiday Inn Express! :dance:
Thank you Chris!!!!
You know, I never had a problem with this beast until I started reading about other mishaps on dropping the LT. It seem that the more I read about the drops and trying to find out how to right it alone, the more I drop it, having to call a friend over to help me pick it up, I was running low on help. I thought the stand worked fine from months and then I was reading about how to be careful in parking her. Low a behold, down she went. Now I have done it three damn times! After seeing this video, I'm ok with it. Maybe by not being worried about it, it won't happen.........Hopefully. Anyway, thanks for sharing your video.
All the Best,..........Ride On :cool:
cws said:
Watch and learn from Mr Munson.
it IS easy
DaleB said:
Excellent! He makes it look easy.
In a drop to the right, I was able to pick mine up unassisted with much less effort than I thought. I did use the "proper" technique as outlined in Munson's video. Works quite smoothly.
Yes, last evening
in the dark, I put my foot down at the end of my driveway on some gravel that had found its way there, and over it went. i had the option of taking the car to work and leaving the bike there for all to see, (did consider it) or pick it up and continue on to work. Which after a couple attempts She came up and off to work I went.
Best.
Not me.. I have never been to the Northwest, nor have I ever dropped my LT. No double digits fall -down-go-ouch for me. Must be thinking of someone else.
1 - 20 of 21 Posts
