Anyone know or have a pic of where the diagnostic plug is on an '05 LT?
I see speaker connectors and a brake light connector and another one along the frame, but nothing that looks like the plug on my GS or my R. The only things I've found have leads going to both ends. Only looked under both seats...
Thanks!
B
It is a grey colored, capped connector along the subframe rail on the right side of the bike just under the rest area for the front seat height adjuster. It is in a clip to secure it. Same size as the speaker barrel connector.
Dunno 'bout the '05s, but on the '02s you'll find a grey screw on cover on that plug on the Right Side, under the driver's seat. Forward of the Brake fluid resevoir. Almost directly under where the famous 'brown wire' is looped.
It's a grey twist off cover - looks like a large toothpaste cover - sorta, if you squint just right and have had a few 'barley pops' on a hot day.
Thanks all... that helps.
Bringing toothbrush and flashlight out to the garage as we speak.
B
