1 - 12 of 12 Posts
OK im satellite radio bound , now how do I hook the thing up..... :rolleyes: It comes with a car kit but its going on my bike i may use the car kit for my ......you guessed it CAR! Cyclegadgets has a complete pkg- radio holder for clutch or brake with built in antenna , 5v hard wire power supply(no cig cord) , direct fm adapter for clear audio , and of course a rain cover. All of that for about 100$. But ya still have to hook it up :eek: So advice advice advice step by step pic by pic or hey maybe if you live close to me (Bristol ,TN) I could feed ya. My brother and I do run a small catering service(Good Times BBQ)
chopped pork , ribs and chicken with all the fixins. Anyway all help I could get would be appreciated. :D
Cycle gadgets package
I purchased the package from cycle gadgets. The XT is not the radio you want unless you are able to take your bike apart and install the FM direct adapter. It comes with a "sure connect" cord that has to be connected to your FM antenna at the rear of the bike. The roady holder in the package will completely block your view of the mirror. They sell an offset holder made for the LT but that is not what they chose to put in the package. So, I ordered the offset bracket and a better rain cover from hoon hardware and a roady2 on ebay. I bought a cig. lighter plug from pepboys and wired in to one of my running lights. I used the cig. lighter power cord that came with the roady2, ran it through the handle bar cover, plugged it in, sealed the connection and secured it a zip tie behind the turn signal. It works fine. Next time I have it serviced, I will let them install the FM direct adapter. Good luck with your install!
Winston
I tried the brackets and ended up just putting a piece of dual lock on the back and stick it directly to the top of the oddments box. That way, when it rains I can quickly stick it in the oddments box and keep listening.
Do the direct antenna connection. You should only have to take the left side off to install it and hide the box under the stingray.
You can also take apart the 5V power supply and hardwire the power in (not to mention weather proof it with some silicone).
PM me if you have questions on the install.
darryldaggs said:
when i get it and the necessary equipment i will let you know should be about a week and half
Hey, Darryl - add this website for some install solutions. The voltage knock-down module, from 12V to 5V, is in a cigarette lighter-type plug, so I used a female lighter receptacle mounted behind the map light and powered off double spade connectors to the map light power-bracket. The cigarette lighter-type plug is thenfed thru the maplight notch and plugged into the side of the XT docking cradle. That takes care of power. For the antenna, I bought a 4' puck antenna from myradiostore and the puck is mounted on the shelf and connected to the side of the cradle. I prolly could have used a 1' antenna lead, butt if I ever wanna change the XT's location, the 4' should take care of that. Extra antenna lead is figure-8 looped around the mounting bracket that is attached to the shelf. The XT has a built-in FM transmitter, so I didn't use the included cassette adaptor. Ole Toad is a '99 and does have the cassette player in the oddments box, butt the FM transmitter seems to work ok, so we'll keep the cassette adaptor as back up if thangs ever change.
The XT radio is mounted into the docking unit, which hangs off the front edge of my shelf. I used a coupla zip-ties to keep vibrations down and hopefully, keep the unit from going south if we hit a beeg pothole, or....
Hope this helps a leetle, Darryl. Smarter folks than me will surely be around to help with your installation when the time comes. If I can remember to buy some camera batteries sometime, I'll take a pix and post it. Good luck with your installation.
Thanks Dick for the info. I recieved my unit today and started first I hooked up my vehicle took about 20 minutes, but im going to change the power supply to vehicle power. I also used the magnet antenna for my vehicle. So I have left my FM antenna attachment I will use this on my bike I think and purchase a power adapter maybe the cigarrette type and wire it in.
Not sure if these pix are gonna work; sumpthin' is goin' on in my software that's weird. Anyway, Darryl - this is where my Roady XT is mounted, including the antenna puck on the leetle velcro covered shelf, which is right above the SmarTire pressure monitor.
Darryl,
PM sent.
I also posted in the XM forum on here directions on how to shorten the antenna cable to you don't have an extra 50 ft of cable with you. It involves a compound solder joint, but even as much of hack as I am at soldering can do a decent job of it. Plus, it saves you a few more bucks and lets you use the little antenna thats included.
Happy installing!
Well my Roady Xt is installed and doing great. I robbed power from the front seat heater and hid all wiring under the seat and some in the BC box. I mounted the radio on top of my radio read out using the Roady swivel mount and 3m adhesive. The antenna is on top of my topcases chrome rack. It is very clear through my headset via the cassette adapter or through the bikes speakers. The jazz across the BRP was great and had some folks checking it out. Thanks to all that helped.
Darryl Daggs
XM Radio
Here is where I mounted my XM radio. I can see it real good and change stations easily.
I use it in the glove box. I installed aux in cable and use Boostaroo amp. I put the antenna on my Z-technick rear rack.
1 - 12 of 12 Posts
