Can the clear wings set in the top left and right side of the dash be easily removed? And if so, would running without them and the windshield in the up position give more airflow to the rider? It was 84 F here today and while not hot I can tell it would be nice to have a little more airflow in the summer when it is 100+.
Those little winglets can be removed as they are fastened with one screw from behind of the tupperware under the windshield.
So you have to remove the windshield first and then open all the torx screws holding the panel plus the one that is behind the map light.
Regards
With windhield all the way down and the winglets turn sideways, you still do not get enough airflow?? Live in Florida and doing the above is good enough for me.
Old Slow Guy in A Fast Car
John I think he's referring to the stationary ones on top by the windshield not the ones below the mirrors.
To combat the heat, I was thinking about installing one of those Goldwing windscreen vents like the one seen in this thread. Has anybody done this on an LT? I had one when I owned a Goldwing (in a previous life) and it worked brilliantly. Of course, the GW windshield is a different design in that it doesn't have a gap between the base of the screen and the dash, like our LT windscreens do.
Regards, Toolman
