1 - 20 of 22 Posts
Has anyone used a cycle lift on an LT? I have a quality unit that has a 1x1 foot top plate. I used to use it on my Electraglide and could sit on the bike!! It's very stable. Gettin too old to work all hunched over!!
AArrgghh !!!
Not sure I would trust an LT on that.....At least not with my balance and cramped quarters it would just take a little "slip" to put her down....
Several of us have the Harbor Freight Motorcycle lift....Works fine....
IBR# 366
Not a good idea. The LT doesn't have a cradle frame like the HD, so the only way you could lift it would be under the engine itself. Besides possible balance issues, the lower fairing would be in the way. And after all that, you'd be covering up the oil filter and drain plug, which is one of the most common service items on the bike.
Take a look under the bike and see what I mean.
For the LT, or just about any other "frameless" bike, these type lifts, and the ones you see at Sears, etc., won't work.
For these you need a totally different type of lift, the most popular are the large plate lifts that you ride (or push) the bike onto. Handy-lift or Ranger to name a couple. Fairly expensive though. Harbor Frieght now has one that works, a lot less money than the Handy-Lift, but also a lot lighter constructed.
Harbor Freight adds $50 charge for items shipped by truck (like that lift) IN ADDITION TO you paying freight company for the freight at time of delivery.
I don't know about the similarities and/or differences between their lift and this one, but this is the best deal I have found yet on this lift ($634 delivered, including front wheel vise).
Anyone have any experience with either lift?
RVB1019 said:
Hf
I have one of the Harbor freight lifts. It works just fine...
Got mine on sale and had a 20 % off coupon to boot...
I just found out there is a Harbor Freight store just down the road in Irving, TX. If I can get the lift from the store and save the freight (and $50 extra fee), then it becomes pretty much a no-brainer if the list performs well enough.
Thanks, John. Now I just need to find that 20% coupon! :cool:
Ditto on the Harbor Freight lift, got mine with the coupon for $240+tax
go to their website and sign up for their mailing list,
last weeks flyer had a 15% coupon but alas it got "tossed" already
Cycle Lift
Thanks for the replies and information gentlemen. I will take your advise. Heck, the lift I have cost over $400. and it is a top quality unit. Guess I'll have to find a HD guy that needs a lift (I know many do) :rotf:
Bike Lift
Before I would put my BMW on a Harbor Freight $300 lift you might want to look at a quality lift for the money. These are used by pros and available to the general public. I've seen the Harbor Freight and for a dirt bike I think it's a great tool, but for $20k hangin in the air? Just my opinion and I've used both.
http://www.kendonusa.com/lift.htm
IBR# 366
I hadn't seen the Kendon lifts before. Interesting option. Plus they're made in Anaheim so I could pick up locally. I'll have to give that some serious thought.
I respectfully disagree
Unless you run a shop and use a lift everyday, the Harbor Freight lift is more than adeqaute,
the big platform is also very convenient to use for other repairs (as my lawnmower yesterday)
and it handles the LT without any concern.
I haven't seen or used the lift your link shows,
but you could buy two HB lifts for the cost and have money left over.
and judging from the picture (in my opinion)
It looks to be much more suited for as you say "dirtbikes".
Harbor Freight lifts
I paid $441.98 including shipping for my Harbor Freight, I did not have a coupon or discount.
I consider the Harbor Freight lift to be a good quality unit, not the best, but good enough for a hobby user.
Note: some time ago the Harbor Freight platform lift which looked like the current one, was rated around 850lbs. So be careful when passing commment on the Harbor Freight lift, are you talking about the older version or the new one? They look pretty much the same but the new one is rated 1000lbs and the older one only 850.
I can substantiate Charlie's comment. I just threw away the box that my Harbor Freight lift came in, and it said right on the box that the lift was rated for 1,000 lb.
I found a $299 price on the Harbor Freight web site, where the store was asking $399. When I informed the store of this, they said "Print it out and bring it in". I got it for $299 + tax at the store.
Be aware that the manual HF lift takes about 65 pumps of the foot pedal to raise the platform all the way. For the occasional user, NBD. Several bikes a day? Dunno ...
- Bob
Good tip. I'll print the web listing, just in case.
HF also have an air powered one for only eighty bucks more at $379. Even with occasional use, I know I would probably regret not getting the powered one. May as well use that 240v 60 gallon compressor for something!
Just Info on Lifts
Quite some time ago I posted a request in re motorcycle lifts on this site. At that time I didn't get a lot of replies so I started looking around for one. The lift I had was strictly for Harley type bikes and would not work on the LT without a bunch of messing around. I finally settled on the Handy Lift 1000 with 8" optional side panels. Expensive? Yes it was, but it is one of the most stable lifts I looked at. There were other cheaper lifts and one or two others that had a greater lift range, but the clear winner was the Handy Lift. I use the lift a lot and it was obvious that Handy Lift was the best as most of the dealers use them in their shops. I will say this regardless which lift you think best, don't make your choice on how high the table will lift a bike. Over 36" and stability of the platform becomes a big issue. I looked at one well known lift that would rise a bike 46" high. The problem was that a heavy bike that high in the air made the lift REALLY wobbly. Rick
Handy
I just bought a Handy air lift about two weeks ago. I wanted American made and it cost a little extra. It works great and is worth it's weight in gold. I have had my LT and CL on it. I cannot imagine working on a big bike without a lift.
Ron
1 - 20 of 22 Posts
