When I roll on the throttle to the stop..I get no light.
Is my cable to tight or a micro switch is bad?
I looked but I can't find a answer.
This procedure must be done exactly as follows while you monitor the "SET" light on the instrument cluster:
1) With the ignition switch OFF, switch on the cruise control. Press and hold the cruise control switch to the SET position and switch on the ignition switch (LIGHT).
2) Release the SET button (LIGHT GOES OFF), move the switch to the RESET position (LIGHT).
3) Release the button (LIGHT OFF), switch OFF the cruise control switch (LIGHT).
4) Switch the cruise control switch back on (LIGHT OFF).
5) Rotate the throttle against the throttle stop (LIGHT), release the throttle (LIGHT OFF).
6) Pull the clutch lever (LIGHT), release the clutch lever (LIGHT OFF).
7) Pull the front brake lever (LIGHT), release the lever (LIGHT OFF).
8) Push the foot brake pedal (LIGHT ON), hold for 5 seconds (LIGHT OFF), release foot brake pedal (LIGHT ON).
9) Rotate the rear wheel (LIGHT SHOULD GO OFF/ON).
10) Switch off the ignition.
This method worked on my '99 and works on the '02.
Woof!
2000 K1200LTC, Champagne
IBA #9289 Booze Brothers #2
Edited by beemerlt (08/22/04 10:15 AM)
Woof!
