1 - 15 of 15 Posts
So it's now up to 32f here and the bike won't turn over enough to start - almost. Anyone know where I can get a battery or jump?
Once the crowd leaves the parking lot, I'll roll it into the sun and see if some heat will get it to turn over.
Wish the guy would have told me the battery was a little weak. I could have stopped and put a new one in yesterday without these troubles this morning.
Don't try to start it with a low battery. If you do, the start relay contacts could weld together and keep the starter running. If this happens try hitting the start button several times to break the contacts free. See if you can get a jump from someone to get the bike started then replace the battery A.S.A.P.
There's a BMW dealership in Pensacola and multiple dealerships in Fort Walton. I believe there is an independent shop in Crestview not far from I-10. Send me a PM ([email protected]) if you need assistance. I can be in Crestview in an hour.
Rob, 2000LT
Navarre, FL
I spoke to the seller and he said the problem is he has 20w-50 oil in it. I think I'll wait until it warms up and see what happens.
He says the battery should be good.
If the battery is "good" even with that oil it should turn over, right?
Have someone help you push start it.
How hard is it to push start? I'm on a pretty good incline here and could probably get it going pretty well. I have about 150' to get it going and then I'm out of room.
Well I found someone to jump it and I'm running again. See you are the back side of 600.
Old Slow Guy in A Fast Car
There is a Battery plus in Clearwater where you can get a battery. You my have to get a ride there. Check with the hotel to see if they have a shuttle service.
Battery Plus
28560 US Hwy. 19 North
clearwater Fl.
727.726.0228
Well, I'm safely home. Traffic was a bit of a bugger bear, but not too bad.
I did notice that the odometer is off, probably because of that 5-mile over issue.
Also, my mileage got worse as time went on. I was traveling around 77 (by the computer) and my mileage was as low as 25. Any ideas on that? There was wind, but I wouldn't expect it to drop the mileage by half. Plugs? Something else?
Larry
(Officially one of the group now)
reset the Throttle position sensor.
1)turn key on but do NOT start bike.
2) roll throttle from full closed to flu open 3 times.
3) turn key off.
4) start bike, reset BC then ride ride ride.:wave
In addition to resetting the TPS, do you have the service history? Could be a dirty or plugged up air filter or critters nesting in the air intake. Sticky brake caliper. Bad O2 sensor. Way under-inflated tires.
Mine has started just fine at temps. in the single digits with 20W50.
Same here. While not single digit temperatures on the K1200LT. I ran 20W50 year round as even in winter we'd get warm days. The only thing I ever noticed was a slow turn over at first if left outside in the teens or 20's at night but it cranked right up.
+1 on resetting the throttle.
Whoo Hoo! Crestview FL, Spent some time at aux field 3 at Eglin, I remember Crestview was an A&W drive in, with a little town wrapped around it...
When my battery was reaching the end of its miserable little life, I had several occasions to push start the big gurl (at the coffee stand!) and she fired right up immediately, I was amazed at how easy it was. Yes, I did get a new battery, it wasn't as easy to push start as it is to push (the button) to start tho...
The odometer is accurate even thought your speedo by design is off. Fortunately you can add a very small jumper wire to the surface mount tabs and have an accurate speedo. but, the wire is soldere3d in place and if ur not quick u can un-solder nearby components.
1 - 15 of 15 Posts
