1 - 3 of 3 Posts
had to get my radio switches replaced today, and on the way home I noticed that the gps seemed to be loose, and vibrating. looked further, and it does not appear to be attached in the front at all. I can pull it up a quarter inch, easy. Is there a lip or a catch that is not set correctly? How much plastic do i need to take off to fix this? or, just take it back to the dealer, since they messed it up!
-M
The only real good way to fix it is to remove the stingray - that involves the side panels on both sides. If you have a small hand and are good with mirrors you might be able to replace the missing screw without removal. Let the dealer deal with it -maybe they will be more carefull next time.
Unfortunately, that is exactly what I thought... :mad:
1 - 3 of 3 Posts
