1 - 16 of 16 Posts
I went out this morning to ride to work on my k1200lt, and wouldn't you know it would not start. The bike ran fine yesterday. It seems to begin to turn over then just stops. I can hold the start button down for a second or two and nothing. There is plenty of juice in the battery. But nothing when I try to turn it over. Every once in a while it seems like it will begin to turn then it stops again. Unfortunately this is my only transportation at the moment. How easy is it to pull the starter and or test it?? Any help would be gratefully appreciated. Thanks. Jeff in Nashville.
Are you sure the battery has a full charge? Even a slightly low battery will prevent the starter from turning over. I'd try a charge or a new battery before going in after the starter. -Chuck-
Course, check the battery connections.
With an 05, I'd assume the battery rather than the starter.
May be you left that little parking light on while you were at work?
Bob, 00LT
Discussion Starter · #4 ·
Well the lights seem bright......lol
Yesterday it ran and started fine the gel battery is one year old, maybe thats what it is>> I hope.
Discussion Starter · #5 ·
I'll have to see, the bike is an 02, did I say 05...ooops
Well I'll give it a try and see what I can come up with. Thank you for your help. Oh yes, even the BMW deal doesn't seem to know this I have asked on three diffferent occasions. What size is the allen wrench bold under the bike, it drain the tranny fluid??? I can't get an answer from the dealer, so I thought maybe some one here might know?? Thank you
Jeff - just for grins, make sure the reverse knob is turned full forward. Bike won't start if reverse is engaged, or nearly engaged.
Discussion Starter · #7 ·
actually I thought about that.
I did have a very difficult time trying to get it to even turn into reverse, like it was stuck, but finally went in.
Tranny drain plug allen size is 14mm.
Discussion Starter · #9 ·
Thank you for that bit, now I have to find one,
Sears don't sell it. Well, here in tenn anyway from what I can see.
Autozone sells a three pack socket set. The 14mm is the only one you need, butt the package isn't expensive anyway.
Discussion Starter · #11 ·
thanks, if it was the battery,
would the starter stay locked, when i hit the start button, the starter moves a bit then doesn't release when I let go of the button.??? just curious, god only knows I don't know.
I had the same problem (starter sticking). Here's what worked for me, as recommended by members of the board here....
1. turn key on
2. if starter starts spinning immediately, hit the Start button a coupla times.
3. starter stops engaging (hopefully)
Discussion Starter · #13 ·
thanks, but the problem is the starter
will not turn. yesterday, it turned about a half turn a few times but is not turning now.
Try "Rockin"
Haven't had this problem on my LT, but, if the starter is "stuck engaged" you may have luck putting her into gear and pushing her a little. Get the flywheel moving and hopefully have the starter retract.
Naturally, you've verified the on/off switch on the handlebars, you're not in gear etc ;)
My experience
In the summer of 2006, I left the key on, ran the battery down, tried to start it and it locked up the starter. Was able to tear the bike down enough to get something in there and bang on the starter to break it free. It worked for two weeks until I rode it to Austin for the ROT. Next day, it would not start. I tried to break it free again without success.I tried to get the starter out and found out from the dealer, it's like an 6 hour ordeal for them. You have to have alot of equipment to get to it. I carried it to Lone Star BMW. Told them the story and the guy who was really nice tried to soothe me by saying it was probably the starter relay. I had replaced the relay two weeks earlier and was 100% sure it was the starter itself....Sure enough, he called and said it wasn't the relay. Two weeks and 1500.00 dollars later...I had a new starter.....
I hope this isn't where you are headed, this was just my experience. Good Luck!
1 - 16 of 16 Posts
