I have an '05 with EHCS and I ride 2-up a lot. I found I scraped both sides pretty easily so I can advise as follows - Side stand, cut the rubber bump stop back by half to allow it to retract higher up under the bike, then trim off as much of the foot on the lower edge as possible. It should be possible to see the scrape pattern, cut parallel to it with a disc grider and cutting wheel. On the right side look at the side of the centre stand leg, on the foot you should see the scrape mark, take to it with the grinder and trim back as close to the support leg weld as possible. Check if the manual centre stand has a bump stop, it may be possible to trim it back a bit. Next to scrape will be the pegs, so if the bike is sitting lower than stock due to spring sag etc there's not much more that can be done without setting the bike higher.
