1 - 12 of 12 Posts
It's coming up to the point where the bike gets field stripped for summer ( too hot to ride time ) maintenance, which includes coolant change.
My question is, has anyone ever used WaterWetter in conjunction with their bmw coolant?
The stuff really works well in cars
I've used it in my K1100LT. Bike seems to run cooler but that may be psychosomatic. I also used to use it in my dirt track car with good results (no antifreeze allowed).
Your mileage may vary, Robert
I've got it in mine right now, didn't notice that the engine temp gauge is showing anything different, but I can confirm it works in the car, so why not?
Water wetter will do absolutely nothing for a vehicle that has a perfectly good functioning cooling system. Cooling systems are designed to maintain an engine at a specific temperature over a wide range of conditions.
Now if what you are riding/driving has trouble doing that then go for it - it will help with heat transfer.
Just got the bike re-assembled after doing some really major maintenance and hard parts replacement. All the 24k maintenance plus interior and exterior fuel and coolant hoses, new clamps, all new body panel fasteners, isolating nuts, clip nuts...well, everything..
When replacing the coolant I used 50% BMW coolant, and the rest as 3 ounces water wetter and water to top things off.
Test ride was flawless, and the seat of the pants observation of the coolant temp seems to indicate a much more dynamic response to any type air flow through the radiators.
I will continue to watch and plan on a hot weather ride today to see how the new mixture reacts, but I think there might be some advantage to this stuff.
Under normal conditions your water pump puts out a constant flow. The pressure and potential volume of this flow varies with the engine RPMs. Where this flow exits the engine is the thermostat. It is a temperature sensitive spring loaded valve which varies the flow rate dependent upon temperature. As John noted, under normal conditions the water wetter will have no discernible effect on your cooling system. While we're on the subject, as I recall, the difference between 1/2 gauge and redline on the LT is 15 degrees. So unless you get into the red area (not just close) it's normal depending on the conditions. In other words your fans do not normally run. They are the last line of defense, creating an artificial airflow through the radiators in stop and go traffic. Does it work? Maybe. Should you be able to "see" the difference on your temperature gauge? Nope. Not if things are clean and working properly.
I do not know to a certainty that it will provide any additional cooling in the bike.
I use it in my car, a gran marguis with the police package, and have seen in summer months a cooling difference of one needle width on the gauge in very hot weather.
Now, whether that needle width is 50 degrees or 0.5 degrees I don't know, I just know the gauge shows a cooler engine. Also used it in a 3 litre Taurus, notorious for heating issues in summer stop/go traffic, to good result.
I also do not know whether surface area of the radiator -v-amount of agent applied is linear or exponential. I had the thing apart and put new coolant in it and figured what the heck I'll give it a try.
I have been monitoring the after ride radiator temps with a thermal gun just for some type of base line in the "after" side of the equation to have comparative numbers for the next coolant change, which will be sans wetting agent, just BMW coolant and water.
SO in a years time I might have something to discuss.
Here is another "test", but not clear it was all that scientific. The difference is pretty minimal, other than during cruise. And if those figures are correct, 147 degrees is actually too cool for efficient engine operation.
I am pretty sure the advantage isn't due to any magic in water wetter, but due to using nearly 100% water as coolant. I'd love to see a test including 100% water for reference.
If it really provides adequate corrosion protection so that water can be used as a sole coolant, then I can see the advantage. However, that doesn't help in cold weather. And the advantage of water wetter added to a normal coolant mix is probably in the measurement noise...
http://www.importtuner.com/reviews/impp_0808_coolant_additives/viewall.html
This is interesting. The MSDS for the primary chemical in WaterWetter:
http://www.chemistrystore.com/polyoxyethylene_nonylphenol.pdf
Chemical used in everything from pesticides to soap.
It's only at about 20 percent in the WaterWetter so the flammability is negated. Interestingly, it's used as an additive in fire trucks to make their water more effective. Makes it penetrate and cling to the surfaces at a dilution rate of 1 to 1000. Weird.
Just changed my 2000 lt coolant
Put evans waterless coolant in and it seems fine.
Does not seem to have air in it, temp goes up, fans both go on.
Temp goes down to middle.
Ran it idle then around the block for an hour plus.
Been running it in my 318 for 1.5 years
My k75 took it well
Any way to know if I have air in system before I put the fairings back on?
It will be let out (if there is any) if you loosen the clamp on the upper cross over hose and slide a screw driver in to open the hose up. Other wise it hides nowhere else.
1 - 12 of 12 Posts
