Pulling Nose Cone to replace hi/lo with HID. When I cut the ty-wrap holding the parking lamp wire and bulb this other connector came flying out from beyone.
Was it plugged into anything? didn't find the temp probe......
Or is it for something else and just held back by the ty-wrap..
Picture enclosed... I hope I didn't break anything.. a little fuzzy but anyone in the know should know about this connector 99 LT
I am guessing it is the temperature sensor connector. The temperature sensor is near to the parking lamp. It is mounted nearly centerline on the bottom of the nose fairing.
Is the temperature sensor for the BC.. I don't have a computer on this bike...
It appeared to by ty-wrapped to the frame with no connection...
JOhn
JOhn
You got it! No BC, no temp sensor.
Thanks David, I knew you knew....etc.......etc....
Tying wire back to frame.
