JimE was kind enough to send me a few yards of conductive thread, and I set about sewing it into the tip of the index finger on both of my gloves. It works great for being able to use the touchscreen while riding. I specifically am using an iPhone, but this will work with any of the glass touchscreen devices like Androids, iPod Touch, etc.
I don't own any yet, but plan to pick some up. Since the iPhone isn't waterproof, I figure I'd never be wearing them and using the phone at the same time.
I did a little riding and testing last night, and they work 95% of the time. I may add a little more thread not that I see which part of my finger I most naturally use.
Glad it's working for you. 95% is better than I usually get while on the bike even if I remove my glove, what with the normal jostling while on the go.
Maybe after you get your solution tweaked you could post a photo of your final "contact patch". I'd be interested to see what you come up with as the optimum size of the patch.
I don't have a clue as to why conductive thread on the tip of a glove would make any touchscreen work better... It's pressure sensitive.. NOT conductive...
Better to fashion a rubber tit on the tip of your finger...Dip it in some liquid rubber. Let it form a sharp point...The reason your glove doesn't work well is because it spreads out the contact patch too much... Perhaps your thread is giving you a smaller contact patch....And in that case I guess it might seem to be an improvement over the glove itself...
Maybe glue a BB onto the tip of your glove...That'd be great till you stubbed your finger on something.
The older phones used a PRESSURE screen with a resistive membrane in between thin plastic and a sheet of glass. The term "touch" screen really should not have been used with those, but it unfortunately was. The new technology is capacitive touch. No membrane, just a glass screen that detects capacitance. Your body is a great capacitor. Zero pressure is needed.
The thread has to contact the finger, BTW, so it must enter the glove. I've chosen to make a large-ish contact patch with a very random pattern, so that it's much like your finger touching the glass. Yesterday I was able to reliably type out a text message with it (while stopped of course).
The pressure screen on my gps works fine with gloves without the thread.
The random pattern seems to work well. Since the thread must touch the finger, I made sure to make it go over seams internally so there would be pressure against the finger. IE, enter the glove on one side of a seam, and exit on the other, loop around, repeat. After tweaking my first glove, and on the other two, I'm seeing nearly perfect performance.
Next up I'm going to build a handlebar-mounted switch to do answer/hang up and music control. It's very easy from an electrical perspective, I just have to figure out a good switch mounting solution and find a waterproof switch. I've considered hijacking the horn switch--who uses the horn anyway?
