I have an '07 with factory CommSystem, iPOD via AUX, NAV III system.
My question is around the NAV III sending audio prompts through the speakers.
1. Can the NAV audio pop through the external speakers?
2. If the answer is yes, would I be able to listen to my iPOD via the AUX port on the CommSystem and have NAV audio drive through the external speakers at the same time?
I'm having trouble getting through the documentation to figure out setting to make this work.
More information regarding what I've played with so far:
  • I've connected my iPAQ hw6945 cell via bluetooth to the NAV system and have gotten that to work. Nice to be able to sync contact lists with NAV
  • I've connected my Nolan N-Com bluetooth setup with the NAV system and am able to receive and make phone calls through this setup. Things are golden so far.
  • I've disconnected all bluetooth devices from NAV making sure I am not re-routing audio to some other devices but still no NAV audio through external speakers.
I would think that while I had the bluetooth headset profile connected that all NAV prompts would route through the headset. I would also think that if I disconnected all headset profiles that the NAV would default to sending it out through the CommSystem and on through external speakers if I do not have anything plugged into the hard link to the CommSystem.
Any help setting me straight or references to docs on this would be grateful.
Think of the comm system and radio as separate items. The comm system receives audio from the radio, the AUX input and passes that to the helmets. There was no design effort to take comm system audio and pass it back to the radio. There is an aux in set of pins in the connector that the comm system ties into the radio on but I'll guess they are not used and may be available to tap into.
Paint me a picture
OK, so I'm having a hard time visualizing this thing and drew a diagram.
So, is what you are saying, based on the diagram I've attached, essentially this?
  • The Outs from the Radio/CD/Aux can all go to the external speakers or the wired helmet
  • The Out/Mic from the wired FRS/Cell and the Out from the NAV III (Alerts Only, e.g., route voice prompts, etc) communicate only with the wired helmet
  • The Bluetooth links between the NAV III, Cell, Bluetooth helmet will only provide communications between the three and nothing to/from the CommSystem
Question - If I used a wired helmet, would the Bluetooth connection between the NAV III and the Cell work through the helmet speakers/MIC?
You are close on your diagram. If you move the speakers down to under the AM FM radio and move the arrow from the comm to the radio that comes from the CD you will have it. The speakers are not connected to the comm system - only the radio and the CD feeds the radio.
The only AUX input you have (in the oddiments box) feeds the comm system not the radio. There is 3 pins on a 10 pin connector that form an AUX input to the radio. That same 10 pin connector is where the comm system plugs in to get its audio FROM the radio/CD unit. There is no provision to send comm audio TO the radio which in turn drives the speakers.
Don't know about the blue tooth as I have limited experience with it.
One correction John. The AUX input on the VOICE II is a direct input into the radio. Any device plugged into the AUX will play through the radio and be heard thru the external speakers, helmet headsets or both. The input for the GPS, phone, FRS or CB does not go through the radio and is only heard in the headsets.
If the GPS was plugged into the AUX port he would hear it thru the external speakers and the headsets. Of course, he'd lose the input for his iPOD. I haven't tried it, but he could use a passive mixer to introduce both the iPOD and the GPS into the AUX port but there would be no muting of the iPOD when the GPS announced; they'd play over each other.
Bruce Hodges
If he wanted to use his AUX port for GPS and iPod, there is a device known as the "Jeff McCraken Audio Box." It automatically switches inputs based on priority levels. I don't know if he still makes them anymore but I put his website link below to give you a resource. He custom made one for me when I was trying to get my old Goldwing set up with communication. If he doesn't make them anymore and if you are a do-it-yourselfer (or know someone who is), he has kindly put a schematic on his site. It worked well. This is a pass through device only. The only issue that I had was related to amplifcation of the sound from my iPod. I did not have a AUX port on the Goldwing so I could not use the Wing's radio system amplifier, thus my iPod volume level wasn't sufficient for me. Consider the link below as "food for thought."
http://www.ldrider.ca/techpages/audiooverridebox.htm
Thanks for clearing that up Bruce. I don't have the VOICE II but I am using the port it ties into.
I have built a simple mixer and added a small amp to boost the levels up. I mix XM, MP3, and GPS through this to get to the main amp in the radio. Of course I believe that you must have the radio in the AUX mode to get this through the speakers. You can't feed the AUX in from say the GPS and have it mix with AM/FM/CD radio.
I also used the AUX out to feed this back to my Autocomm unit so I can have it in the headset.
Updated diagram
Updated diagram attached.
So it would appear to me that using Bluetooth is mostly useless for anything other than NAV and Cell. Seems like a lot of money to spend for Bluetooth just to keep from being wired. Having had many touring bikes in the past, I've always been nervous about being tethered to a bike in the event of an emergency. Pray the quick release releases.
Thanks for all your help guys. This makes things a lot clearer. I may take a poke at the schematic and see what I come up with but for now, it would seem that being wired has the most functionality. :v:
