Hi,
I found fluid on the clutch actuator rod past the felt seal
I was lucky, since it only penetrated a 1/2" or so. The cluctch was unaffected!
Go ahead and replace the seals, felt and drill holes in the clutch housing (for main seal leaks) and slave housing.
Go ahead and buy a lottery ticket, your luck may still be holding out
