Good Afternoon all and thanks in advance for any help given.
I have an 01 LTC and while riding yesterday I noticed some discoloration on the clutch cover. When I pulled over I could see that the reservoir cover had fluid leaking through the screw (the one one the left and closest to the rider)
I then figured I would take out said bmw tool kit and tighten the screw. No such luck the screw was loose as a goose. The screw is not stripped but what the screw goes into is.
I am thinking the clutch housing.
Any suggestions on how to fix without replacing the Clutch Lever Body.
I did take another screw from a different location and its the same result.
Not exactly sure what would cause this since I have put on 3500 miles since its 36K service last year.
Thanks for any help.
