Just finished up a clutch rebuild and am having a problem - hope someone here can help out.
Got it all buttoned up and off the lift, drained the clutch master (installed new slave) using still installed grub screw and pressing in that small decent to let it gravity drain. (Ran about three full master cylinders worth of fluid through it.)
Went until it drained clear HOWEVER now the clutch lever pulls in to about 1/2" from bar and clutch does not engage. That is, I can hard shift into 1st but when I try and pull clutch lever it's "hard" and does not disengage.
Any ideas?
Any ideas?
