1 - 11 of 11 Posts
Looking for those so that I can make one. Same for tool to hold it in place while installing everything.
best from T'son
Bob
With the drawing Axle sent you just use the release rod for the center element.
Many thanks for your time and the useful information.
Best from T'son
Bob
Reactions: Patric
Socket? 9mm hole to route the rod thru.
I took apart a spring loaded center punch from harbour freight, wrapped some tape around the handle, slipped on the plastic insert from the new clutches spline, and will drill out the inside of the punch for the rod.
As shown in the picture, one of the sockets from my 3/8" SAE set was the exact size needed both to fit both around the rod and into the clutch plate splines. No disassembly or tape required.
BTW, this was not my idea, but -- like almost everything I've ever done to the LT -- came from this forum...
Reactions: Patric
I used to fiddle with alignment tools but really when you look dead on, it is pretty obvious if you have it right.
Reactions: Patric
Just make sure the clutch is continuously pulled in when doing the final pull up of the engine to the transmission to minimize forces on the alignment system
Sorry Niel but that is hard to do when the slave is on the back end of the transmission and that sets the push point to release the clutch. I have always had the transmission just slide right in to place with the eye-ball alignment.
1 - 11 of 11 Posts
