I have an 2009 K1200LT that has something loose under the bike. When I hot a small bump in the road something goes Clunk Clunk in the are of the center stand. When I put it on the center stand or side stand I can't fine anything loose. Any ideas?
Jim
Jim
I think the center stand rides against a rubber bumper when up. Is that still in place?
Jim
Also, there is a large bolt that holds on an exhaust mount. If it wasn't put in with some blue loctite, it can come lose and fall out. That can rattle. Something to look for.
check the rotors, rubber stoppers in the exhaust cover for the side stand and the other points as mentioned,
I had a clunking noise on my 2000 LT. The culprit turned out to be a cracked from fender where it attaches to the front folks - seems to be a common problem on early model LT's, the later LT's had a better design.
The winner is Manfred it is the rear brake rotor that's loose is making the noise.
The rubber number stoppers for both side and center stand are in place and the exhaust bolts are tight.
Parts on order.
Thank You to all for your help
Jim
Parts on order.
Jim
The rotor rattles. It doesn't clunk.
:smile:
