What's the best cleaner out there for cleaning up the bottom of the engine & intermediate housings from a leak? I was gonna shoot it with brake cleaner, but figured I'd better hold off to make sure it's safe for all the materials it might end up on. I could spray onto a rag, but it would be hard to get up in between the fins & such...
have you tried "purple stuff" ?
The Villages, FL
When I change the oil, I always use brake cleaner to clean the oil filter cover while holding it over a trash can. It is better than taking a rag and cleaning between the fins. It dries fast and is easier to handle when re-installing. Anyway, brake fluid should not damage anything, just keep it on the engine parts.
brake cleaner
be carefull,read directions on can. the brand that i have (gunk) says to protect rubber and plastic brake parts,seals,and painted surfaces from spray.
MMM.....
GoJo.
Cleans grease and oil from anything.
I scrub the chains on my other bikes with GoJo and a scrub brush.
Best yet is when you splash it all over your clothes, it wash right out.
