Is it me, or it is downright impossible to go fit a gauge or an air pump down there, unless you crawl on all four. And even then. I can't believe BMW had the flash of genius to put the valve dead in the middle of the rim. If you have a pump or a gauge that require a straight fit in, like the ones with a dial and a rubber hose, you're doomed. And of course, you either have the can on the left side, or the brake disc on the right to complicate things further.
Someone has a trick to share with me?
Thank you.
Thank you.
