1 - 11 of 11 Posts
IBR# 366
Saw this posted on a different riders forum:
When prompted, we got a few more pics:
Obviously, the rear lug bolts loosened up and fell out, causing the rear wheel to extricate itself from the bike. :eek:
Fortunately, the rider wasn't going all that fast, was ATGATT, and escaped without personal injury.
The rider said they'd bought the bike used a few months back and hadn't yet messed with the rear tire at all. So whomever did the last tire change clearly didn't torque the lug bolts down properly.
Note this is an R1100R, but I'm posting here because the final drive and rear wheel mounting procedure is similar for R1100, R1150, and K1200LT bikes.
From the R1100 BMW Service Manual:
Use no oil or grease on the rear wheel studs.
Hand-tighten the rear wheel studs in a cross pattern, then initially torque to 50 Nm (37 ft-lbs), then final torque to 105 Nm (77 ft-lbs).
Again, this is the same for the K1200LT rear wheel.
Newer R1200, R1250, K1200, K1300, and K1600 bikes have an inverted Paralever drive with a wheel flange, so they have different torque specs. Note that this wheel mounting flange can be damaged by over-torquing. There is an official BMW Recall Notice on this issue.
From the K1600 BMW Rider's Manual:
Tightening sequence: diagonally
Torque: 60 Nm (44 lb/ft)
I can personally vouch for the fact that the K16 rear wheel can loosen up if the lug bolts are not tightened properly. Fortunately, I noticed that the bike felt squirrrely, pulled over into a safe place, and was able to re-torque them correctly (I carry a lot of tools onboard).
So the moral of the story is: Check your torque values (front and rear wheels), and always wear your gear...
I have to admit that I still wonder how someone could ride a bike with loose lug bolts and NOT know that something was up. I always try to be very careful when installing the rear wheel and ensure that the bolts and threads are clean and dry and that everything is in place squarely before torquing. And I always use a torque wrench if at all possible. Thought I was going to have to do a “calibrated forearm” torque at last years CCR when I had to replace a tire in Arkansas, but Mr. JZ just happened to be packing a torque wrench that he let me borrow. I think I could get close by feel, but I’d be stopping a few times to check things if I had to torque without the benefit of a torque wrench.
I’m also glad the LT has the 5th bolt. Every extra bit of insurance helps.
Goot-N-Tite is not the right tightness. Returned that wrench and socket to JZ at the Ironhorse fall reunion. He was happy to lend it and also glad to see it back.
I agree. I occasionally get razzed for using torque wrenches as religiously as I do on my cars and trucks, not just my motorcycles, but you see things like this and feel pretty vindicated. It is great that this person was both prepared (ATGATT) and lucky. This could just as easily happen as you approach a semi and the outcome might not be nearly so happy.
I was very glad John had show wrench with him and was willing to leave it behind when he had to leave early and I greatly appreciated your willingness to transport it back. I could have gotten by without out, but I would have had much less peace of mind for at least the first couple hundred miles on the way home.
Reactions: beech
IBR# 366
The original poster is kinda new to riding, and has only had the R11 for a few months. He did say it started feeling bit weird, but he was close to home—and that in hindsight, he shoulda just pulled over immediately...
I have a torque wrench that has travelled with me all over the country, including to a number of CCR's over the years. Those Tech Sessions sure were fun. :bmw:
It's tough to find one that covers 105 Nm and is short enough to fit in the top case, but since I no longer have an LT, I just need to cover 60 Nm which is much easier.
Gotta be able to pull either wheel at any time, and to put them back together correctly...
https://www.northerntool.com/shop/tools/product_200712282_200712282
Reactions: meese
Reactions: meese
You should see the ones we used on the E-2, C-2 and C-130 props.
I had to go find some videos to see how it worked as it was not totally obvious. Planetary gear set inside. You will have to brace the " handle " of the tool to allow the planetary gears to do their thing. Cool tool.
Yes, planetary gears are almost like magic. :grin:
Reactions: bmwcoolk1200
IBR# 366
Here's a reduction gear set, where it takes 13.7 billion years (the approximate age of the universe) for the last gear to complete one rotation.
And a video of the gears in action.
I have to admit. 4 years back. A few of us were riding thru DC/ Maryland area to get seafood at fisherman's Crabdeck. Riding spirited down Rt 50 in W Virginia. My rear tire failed. Went got a tire, no torque wrench. Had to do by feel. Didn't have a problem. But I'd like to think i'd know if they got loose. And i really like that the LT has that center lug. I think that helps.
1 - 11 of 11 Posts
