Gosh, interesting. What sort of price are you paying on top of a tyre to get it changed ? I don’t know whether I could be bothered. Generally the price of the tyre includes the fitting over here. What about the balancing ?
Are you equipped for a bit a metal DIY? If you have the skills and tools, you can make a first class changer out of parts readily available.Otherwise, which tool are you using?
I'm paying $102.61 (~76USD) for them to replace the front and rear tires. This includes balancing and shop supplies. This is with me bringing in the wheels loose, already off the bike.Gosh, interesting. What sort of price are you paying on top of a tyre to get it changed ? I don’t know whether I could be bothered. Generally the price of the tyre includes the fitting over here. What about the balancing ?
Which model did you buy? You're happy with it? Does it require a hub adpater for our wheels? Do they sell one, or did you build one?I bought the Nomar system and it paid for itself in the first year since I work on bikes on the side. The system you are looking at should do the job as well.
Rabaconda sells the adapter to fit our wheels. Thank you for the details though. That's a nice machine you have. I think for what I need, it's going to be a bit too expensive and take up more space than I really have available.You will need something to hold the rear wheel with the larger hole BMW has there. The bolt hole is on a circle of 120mm and the bolt threads are 10x1.25mm if you have a lathe.
Thanks for the info. I'm going to look into this tomorrow when I get a chance. Making one from scratch won't be an option for me. I already have enough side projects and never enough free time to work on them. I'd like to buy something that is ready to go out of the box!Are you equipped for a bit a metal DIY? If you have the skills and tools, you can make a first class changer out of parts readily available.
I thirst bought one of these off eBay: https://www.dtmtrading.com.au/product/multi-tyre-changer-21/ The link is just an example, I didn't use that source. I used that changer as is twice. It makes the job difficult and very hard not to mark the rims. So further research lead me to max2h.com They seem to have disappeared since but you can find videos of their product. This guy built one from scratch:I then combined the changer I already had with the duckbill adapter and bits to be able to use it with the rear tyre on the RT.
The end result is a 5 minute (no exaggeration) machine that takes very little effort for well under half price of the Estonian thing.
If you decide to build or make your own, I am happy to help with photos. Or you can move to Perth and use mine![]()
Truly depends on how may bikes you have. I have 4 street bikes and 4 dirt bikes for our household so I change all my tires. Different tools for different bikes, I have a simple No-Mar tire manual changer for the street bikes and use the bead breaker for the off-road stuff with lots of spoons with a balance stand for balancing.Gosh, interesting. What sort of price are you paying on top of a tyre to get it changed ? I don’t know whether I could be bothered. Generally the price of the tyre includes the fitting over here. What about the balancing ?
I only have the one bike right now, but sometimes I have two at the same time. I've already spent over $200 having tires changed on my bike over the last two years. I should have just put that towards a machine. It will pay for itself eventually. Or, very quickly if you do some side jobs.Truly depends on how may bikes you have. I have 4 street bikes and 4 dirt bikes for our household so I change all my tires. Different tools for different bikes, I have a simple No-Mar tire manual changer for the street bikes and use the bead breaker for the off-road stuff with lots of spoons with a balance stand for balancing.
Change Your Own Tires!
www.nomartirechanger.com
If I only had 1 bike I might take my wheels to the local shop
That's a great point. I have a rear tire in my garage right now that I know I can get a few thousand km out of. It's just not really worth paying someone $50 to mount it for me. I will have to look into the No Mar unit. Right now I'm leaning towards the Rabaconda Street Bike Tire Changer.Especially when you take off a tire that has 2k miles left on it and you have a 2k+ trip upcoming.. you can save that take-off and put it back on when you have some shorter rides coming up... I usually wait til that new tire is worn... yes, you may end up with several almost-worn tires but it works itself out.
The interesting part is how many friends you end up getting .... lol
Yeah, it does. The duckbill is the game changer for the manual machines. The ratchet is the thing I never seen anywhere else. I made my duckbill head reversible so I just insert the handle in the opposite end to keep going around the tyre.Here's a video showing how it works. It looks really slick...
Yeah, bolted to the floor would be nice, but I don't have room in my garage to bolt anything down. I considered bolting one to the floor in my basement, but I like the portability of having it unbolted. I believe some of the No Mar units can attach to a truck hitch. I'm considering this as well, but leaning towards trying this Rabaconda. I've watched lots of videos and it seems to work very well. The only people I saw struggle were guys who weren't following the instructions properly.The only downside to his system is the bending over part. That's where a no-mar style system works better. Also, having things bolted to the floor makes the entire exercise easier. Admittedly though this system is sold as portable and for that it is better than the max2h changer that requires knee pads
The important part with any of these contraptions is warm rubber and LOTS of lube. I usually apply it so the inside of the bead gets a bit too, makes popping the tyre onto the rim easier and removing it the next time too.
I have the hitch attachment as well and also got a hitch riserI have the NoMar and I cannot anchor to the floor. My shop has hot water in the floor for heat. Would love a suggestion on how to have something attach to it so it would be stable? I purchased the hitch attachment but it’s to low.
Sent from my iPad using Tapatalk
Buy a section of 3/4” plywood large enough you can stand on to hold the changer down when using. A rubber map underneath will protect the garage floor and reduce movement. Use carriage bolts from the bottom to mount the vertical support of the NoMar. You could add some retractable wheels on the 4 corners or I just use 3 or 4 pieces of ½” x 3’ PVC pipe to roll the setup to the corner or side of the garage.I have the NoMar and I cannot anchor to the floor. My shop has hot water in the floor for heat. Would love a suggestion on how to have something attach to it so it would be stable? I purchased the hitch attachment but it’s to low.
