So this is the second time I`ve changed the oil, and the second time this scenario has occurred ; When I take off the oil filter cover, the oil is draining from that location, all of it.The first time it happened, I thought that the oil filter was loose, as I later found it to be, and when I reinstalled it, made sure that the filter was on correctly. This time, the same thing happened again, however the filter was not loose. Took the filter off, checked for defects, found none, reinstalled the filter, and this time I did not put the oil filter cover on before refilling with oil. As I pourd the oil in the fill hole, it ran out from around the oil filter. Is this supposed to happen? The bike runs perfectly during normal operation, no leaks, no knocking, I just have this weird occurance when I change the oil. Whats up ?
