1 - 3 of 3 Posts
I pulled the center bag off the back of the bike a while back. The bike handles completely different at higher speeds. I have one problem My front lighter is dead. checked all the fuses not prroblem.
Could it be that the rear bag light connector is wired in series with the on in the front and I have broken the circuit?
Betcha if you stick a volt meter in the socket you'll find it works my rear port doesn't appear to work while my front does ....they both work its just the sockets they seem to be a bit inconsistent for the plug's
by "lighter" I am assuming you mean the power socket lower left side? no its not, check the wire is on sometimes its left off when the lower fairing is removed for service the rear only work when the ign is "on"
1 - 3 of 3 Posts
