I have notice that the center stand (hydraulic) have a small leaks oill at the end of the shaft.
how i can fix it? is there any site to inform or expendable supplies ?
Hi Dimitris,
My center stand also leaked.
I am in the process of rebuilding mine. I have some US seal numbers that will probably due you no good in Greece.
The manufacturer of the seals is "PDF". These two links may be helpful.
Thread #1
Thread #2
I've talked to a few who have only had problems with the 40mm ID x 2.0 mm O-Rings. Perhaps you are this lucky?
I've got some seals that should be delivered to me this week and I'll go from there.
I'm trying to write up the procedure, but, I chose to remove the entire stand and work on it on the bench.
I've been using my side stand only in the meantime.
Good Luck,
Joe
