1 - 9 of 9 Posts
Need to order a new screen, wife says she would like less air then the stock sheild, she is 5' 10"...
Considering the touring screen -1
Comments from those who ride 2 up would be great !!
Thank you
I bought the stock size CB, and both the navigator and I think it's got better airflow characteristics than the OEM piece. Can't explain it. But it's better.
However: I'm 5'10" and she's only 5'7". With your wife's height, you might want to go a tad taller.
Just my $.02 worth. Hope it's of use.
Don
Don
Short Hi-Jack --- Happy Birthday, Don!
It makes a difference if you are getting the style #2 or not. The flip at the top raises the shield considerably. I'm 6'0" and shrinking. I tried the style #2 -2 and it was to tall. I now have the #2-4. Great shield. I might try #2 -3 next time. I also have the wings. My wife says they make a big difference. My 2 cents. Hope this helps.
I am 6'2" and have #2 -2 and love it, wife is much shorter so height is no problem for her. But, like someone said #2 shield seems taller than regular.
Leon
05 Blue LT
CeeBee
I tried out my new CB #2 -1" today for the first time today. I'm about 6' 1" and have been using the stock shield for 3 years or so. The main thing I notice is that with the CB shield fully down, I get much less direct air in my face than before. I would have to raise the stock shield about 2-3" before to get the same effect. And doing so would put the edge of the glass in my line of sight, which I don't care for much. It is much nicer to look over the glass than through it, IMHO. So, on this I am pleased. The #2 curve creates a low pressure area in the rider area that is somewhat noticable in my ears, kind of like being on a plane changing altitudes. I have a half helmet, so maybe that's why I notice it more. I also agree that the shield "seems" bigger although I know it it actually 1" smaller as measured down the center. I believe that the upper corners flare out a bit more than the stock unit.
I have just recently gotten my Cee Bailey #2 at stock height and the jury for me is still out. I went from a Euro cut to the #2 and at 6'5" I get a huge amount of buffeting behind the screen no matter what level I adjust it.
If I did it again I would have probably gone a #1 -2, the Euro cut I had was probably 7 inches shorter and with it all the way up I was fairly comfortable. The other thing I don't really like is that the scoop at the top distorts vision and that is right in my eye line if I raise it up at all, I can just look over the top with it all the way down.
My 2 cents worth anyway.
I'am 6' and my SO is 5'11 and I have the Cee Bailey #2 w/ wings- standard and my SO loves it. I could prob have gone minus 2 and it would not have made much diff.Hope this helps.
I am 6'0 and Karen is 54'4
We have a #2 -3 with wings.....
Both love it.
1 - 9 of 9 Posts
