Is there an easy way to remove a stuck disc from main player on a 2002 LT? Unit tries but will not eject after repeatedly hitting switch.Can it be pulled outwith tweezers?
This happened to me couple years ago. I didn't mess with it much, dealer replaced it under warranty rather than repairing it.
Look for a very small hole near the CD slot. If it is there use a straightened paperclip and stick it in the hole (with power off) and push. It should manually eject the CD. I have a 2002 also but it has the tape player so I'm not sure the hole is even there. Don't try to forceably pull the disk out with tweasers or plyers though.
Thanks gentlemen for your ideas but my wife actually gave me the idea of using duct-tape on a putty-knife to pull the cd out and it worked like a charm while hitting the eject switch!
