1 - 3 of 3 Posts
Hi all,
My radio/cd display is showing a message " No Discs" when I attempt to use it.
The cassette cartridge has 6 cds in it and when it is inserted it clicks and whirs as it checks each cartridge insert but the display still shows no discs found.
Any ideas?
I had that same problem with mine several years ago,and what I discovered was the lens was dirty. Got a CD disc cleaner at Best Buys and it worked find after that. As an aside, a month or two after that I took the CD changer out, and replaced it with a DIce unit, and now just play my IPod via the Dice unit. Works much much better. Plus it give you more room in that saddle bag.
If this is the first time you've tried to play a cd since a battery disconnect, then you need to press the cd button on the radio a second time then it will play if all else is OK. Cleaning , as mentioned above, can also be the trouble although I haven't cleaned mine and use it dailey since I bought the bike 4 years ago :bmw:
Good luck.
At least that's how it works on my '03 LT.
Vern :bmw:
1 - 3 of 3 Posts
