1 - 3 of 3 Posts
As a relative newbie, I am always nervous when it comes to turning a wrench or screwdriver on my baby. However I would like to remove the CB radio from the oddments box, to allow room for other things, as I never use the CB radio. I looked at it and it doesn't look like it can be easily unplugged. Can anyone tell me if they have removed it without removing tupperware?
Thanks in advance.
Rich.
Not as hard as it looks just take your time
And photo everything before you take it apart
If you have no use for the cb I would make you
an offer been looking for one for my 03 if it will work
Working on your own bike is so much fun and it will
make you feel great
Ernue
You can't remove the harness without removing some tupperware.
Remove the tipover wings (jpegs if you have them)
remove the chrome covering the bars
remove the left turn signal and disconnect the bulb
remove the center tupperware (under the oddments box)
remove the upper left (shift side) tupperware
With the radio console loose on two sides, carefully lift up the console
carefully find the connections to the CB and disconnect them. Double check that the CB is the only thing you disconnected.
1 - 3 of 3 Posts
