I can't speak to the system on the 1250, but on my 2018 1200RT I can regulate the amount of pressure that the brake applies with the pressure that I apply to the brake lever. Pulling it very hard means I have to give it lots of throttle to get it to release. Pulling it gently means less throttle to release it. In either case though, it seems that just flicking the brake lever with moderate pressure will get it to release.Are they saying the amount of holding pressure can be controlled by the user, or are they saying the system automatically senses the amount of brake pressure to be applied for a given activation so is not under the control of the user? It must be the latter but I suppose one might argue there is a range of levels of brake lever squeeze to get HS to activate, and pulls on the more extreme end of that range result in greater holding pressure, so in this instance the user does have control.
They do. The system is flawless on my 2010 Bimmer.If I could give it back I would. Never use it and never will.
I really wish it worked as seamless as my car. When I let off the clutch in my car and give it gas I have to do nothing different then if I was sitting on level ground.
If it was implemented as seamless I would love it, but compared to my 6 speed Honda it is a very bad solution to a problem that never existed for me on a motorcycle.
I would hope BMW cars work smoother then the bikes.
When I first read of HSC I thought, "Why would anyone want or need this BS!" It sounded like a solution in search of a problem, something that a geek, who had never ridden a motorcycle would invent, to "make it better for all us poor, incompetent riders."If I could give it back I would. Never use it and never will.
It's very nice to have to free up your right hand if you don't put the bike in neutral at stops which I never do--I use it frequently. That it doesn't disengage seamlessly isn't a big deal, just wasn't expected. I enjoy all of the other tech features as well and they all work wonderfully. It's hard to fathom you can actually own all of this wonderment and have it work for you flawlessly. I keep expecting something to go awry but so far so good. Except my rear TPM's battery must be nearing its end of life.I’m no longer a Luddite when it comes to HSC. Now I'm a fan.
Just to clarify things, I hope!I can't speak to the system on the 1250, but on my 2018 1200RT I can regulate the amount of pressure that the brake applies with the pressure that I apply to the brake lever. Pulling it very hard means I have to give it lots of throttle to get it to release. Pulling it gently means less throttle to release it. In either case though, it seems that just flicking the brake lever with moderate pressure will get it to release.
Using the hill hold manually it is a really useful feature, in auto mode I think it's a liability.
I agree that being surprised by this feature on automatic might be a very bad thing should stuff happen. If I had this system, I'd have it on "manual." Being surprised, as the OP was, I'd probably have tipped over too! I hope the Tour Guide sets them all on manual and explains the feature to new riders, giving them the option to shut it off completely.Agree, how many times have you had to act ‘faster than expected’ to avoid a potentially dangerous situation. If you were not aware that hill start control was engaged, you might force an engine stall at a time that would put you in danger !
The Hill Start is totally different on my 1250, on my 2014 I used to have to rev a lot to pull away and it was easy to stall it. On the 1250 its seamless and seems to work a lot better. Switched off the auto engage within 15 mins of buying the bike though.On my 2016 I can feel it engage when I squeeze the brake lever. I find it totally predictable.
Never had anything like the experience you describe.
And yes, when used - it stalls more often than not. I hardly ever use it. The only exception is when I have to hold on an uphill for a long time. But I still disengage it and do the hill start the good old fashioned way with rear brake....
Not a feature I would recommend to any new buyers.
Maybe the newer models are better - but I doubt it.
It is best to deactivate it before releasing the clutch.I don’t think you can deactivate it on the 1200 since you have to give the brake lever a pretty hard squeeze to make it come on. I haven’t used it that much ,but when I do I kill the bike about 50% of the time when I take off. Needless to say I use it sparingly.
I second this post! The AUTO hill hold on my 1250 RT is a liability and nearly had me over twice in heavy traffic on a very hilly, winding road (near Cadwell Park for those Brits on here!) when I tried pulling away without enough throttle to overcome the brakes and the incline. On reaching my destination I selected MANUAL hill hold and that functions really well, far better than on my previous 1200 RT in fact and I use it all of the time.Just to clarify things, I hope!
The 1250 has an inertial motion sensor that informs the traction control and ABS system about the bikes attitude and how much assistance is required to prevent wheels locking or slipping when braking or driving.
The same information is used to tell the hill hold system when the bike is on a slope. When the bike is stationary and on a slope, with the engine running the hill hold will operate if it is in automatic mode. Tellingly it only applies enough brake pressure to do the job so normally pulling away afterwards is much easier than on the 1200.
On a steep slope it applies plenty of brake pressure and you don't know it's even activated unless you look for the symbol on the screen, not necessarily a convenient thing to do in a busy traffic situation. This is what caught me out!
before the light changes I’ll always disengage... and regrab brake.... but like most of you I did choke it down a time or 2I use it every now and then. I always disengage before attempting to move.
+1.before the light changes I’ll always disengage... and regrab brake.... but like most of you I did choke it down a time or 2
