1 - 20 of 21 Posts
Overfilled my gas tank and bike started running bad (surge, stall at stops). Also when I open the gas cap there is a air rush sound. I also see a small amount of gas dripping out of the vent hose in the back of the bike. So will this problem clear up on it's own since the vent hose is getting rid of the excess gas? Or will I need to remove or replace the canister.
Joe
I'd remove the cannister. There are very detailed posts here to guide you through it. PM me if you can't find them. Either way, don't wait. You can damage the fuel level sender when the vacumn causes the tank to start to collapse.
You should remove the canister, the sooner the better. Once fuel gets into the canister it clogs up and the pressure buildup can collapse the fuel cell, which along with being expensive to replace, can damage the fuel pump and fuel gauge. There are instructions posted in the Hall of Wisdom, and I've attached instructions I wrote up a while back with the help of some fellow LTers.
Canisersctomy
Thanks Dave,
Just one question. What is the purpose of putting a screw in the intake hose? Do I want to block the hose from sucking in any air? If so why?
Just a guess, but the hose mentioned goes to the 'intake' for the engine... I think it is called the "purge" line...probably part of why your engine is running poorly is that it is allowing fuel to be pulled into the engine from the cannister rather than "vapor". You would want to plug that... not the fuel Cell vent line.
Joe
I had this happen on mine once, it did clear up, I do not want to remove my canister, the one thing I do NOT miss at all is the smell of gas in my garage. when I owned all hd's you could smell gas , since we own bmw's you don't at all. it's great!
Tom
Caniserstomy Operation Complete Patient Doing Great!
Well I removed the cannister and all is well. No more stalling or surging. I also installed a inline fuel filter $2.48 on the vent hose, no smell of gas. Just for fun I blew air into the cannister and sure enough out comes lots of raw gas. Thanks again for the wisdom of this board.
Cannister's been removed from mine for a while Tom. I have no, repeat NO, gas smell at all from the bike. It is one less problem to have creep up on ones self. YMMV.
now do that to 4 or 5 bikes in the garage then quick light a match!
<g>
Problem? sure if you dump the bike and fill the hose with gas it could be a problem, but outside of that there is absolutly no performance or mileage gain by removing it, and trust me if you had a few bikes that vented direct to your garage you would smell gas
I have a newbie question about this issue.
I do not think I have overfilled my Gas tank but I am not sure how I would know. I have never had gas poor out over the tank if that is the issue.
I do however have the surging issue. Should I remove this canister as well?
After a ride with our Daveh, I started having symptoms so I did the canisterectomy last Saturday. It is the first time I ever disassembled any part of my bike so I was nervous. It went without a hitch. The bike is running smooth and powerfully with 44 mpg at 70mph, two up, loaded cases and Cee Baileys #2 up all the way, just like SWMBO likes it. No gas smell at all.
If you are concerned about not having a canister, you can replace it with a new one, BMW part number 16131464924, about $38 from the dealer. You need a new cable strap to hold it in because you must cut the old one to get it out.
Rider Journeyman
Howdy Rovero,
Please fill in your profile so we know what model year we're discussing,
though it's not important in this case since you've eliminated your problem with the canisterectomy.
Since you had the "whooshing" sound of a the vacuum created by the clogged cannister, I would recommend keeping a close eye on your fuel gauge for a fill-up, or two. This is in the unlikely event that the vacuum that was created caused the float tube to collapse and impede the float ball travel.
If your fuel gauge is working okay, then you probably don't have any damage.:cool:
For those that are wondering why most everyone is so insistent on removing an emissions control device: This canister can become clogged by fuel overfilling, spilling over if the bike is dropped and by "sucking up" rain water while riding. The clog can cause the fuel gauge to give a faulty reading due the collapsing float tube and, worst case can actually collapse the fuel tank. :eek:
I am personally adamant about it's removal after sitting on the side of road in the deserts of Nevada with an incorrectly reading fuel gauge showing 1/4 tank when it was in fact, bone dry. :mad:
What year is your bike? There could be several other reasons for your surging, depending on year and a couple of fixes.
I don't know if there are warranty issues if you remove the cannister from a bike still under warranty. What I did was disconnect the cannister, plug the line running to the intake, sealed the intake to the cannister and ran the rubber line from the fuel cell down toward the ground.
Now, when I go in for a service, I simply reconnect everything, and no one is the wiser. Maybe what I'm doing is needless, but I don't want to take any chances.
Sorry, I have a 2005.
I was also wondering about the fueling procedures. I fill the tank till the pump cuts out, but that does not fill the tank completely. I do not think I have ever gotten the tank full (at least on the gauge). Should I look out for something?
Fill er up when it's on the sidestand. I would rock my bike back & forth gently until it was truly full. It takes patience more than anything.
Never stick the nozzle in like you do on the cage - could hit the fuel sending tube. I put the very tip "just" past the ring at the bottom of the filler and go for it (on the side stand of course). Never had an over fill problem. And always get it topped right off.
1 - 20 of 21 Posts
