It could be the slave cylinder or master cylinder beginning to fail, or in the case I worked on yesterday, the clutch pack failing. The bike I worked on yesterday is a 2015 GSA with 77K miles on it.
You may want to try bleeding the slave cylinder to see if that helps. If it does, air has made it into the system somewhere and you'll need to figure out where or the problem will come back.
If the clutch pack is worn out you'll need to replace some or all of the parts depending on what you find.
