It's time. I bought the bike used, with a new front tire, and a slightly used rear, both were Metzler 880's, which all in all is a pretty good tire. I changed out the rear about 8,000 miles into it, again to a Metzler 880. I did not change out the front, because I'd like to switch to a stickier tire, with better rain performance. Mileage isn't that critical (nobody said we had a cheap hobby). I was going to change both the front and the rear at the same time, probably to a Bridgestone (?????).
I mis-timed it. The front is bald (with the standard wear on the left), and I am going to the BMW rally in Texas this weekend. I gotta do something before I head out, but the rear Metzler still has almost half it's life left.
Opinions?? I don't want to buy any more Metzlers, because I've been slipping around as it is. Anybody want a slightly used Metzler???
Thanks for the quick responses, I gotta do something this afternoon.
Robert
Robert
Put a Bridgestone BT020 BIAS ply on front, and no problems. Mixing brands is not an issue, mixing Bias and Radial MAY be, but even that is debatable.
I have a bridgestone radial on the rear and a 880 on the front. I have run this combination for 3000 miles without any problems.
I know alot of people on here do mix brands, and have no problems. I was at a tire Seminar at this year's CCR, and the presenter, TJ Tennent ( I believe his name is) says that you should NOT do this. The tires are of different compound and developed with different performance philosophies. Just telling you what he said. BTW, I would be interested in a slightly used Metzler, depending on wear and price.
I also would be interested in a slightly used ME880 Rear - PM me with what you want for it. I am also out of sync with my front and rear wear.
No
The advice from a genuine tire engineer that spoke at CCR is don't mix brands and don't mix bias and radial.
I need an new front tire to replace the BT20 radial. The rear still has half the tread ware.
I decide to switch to the 880s since the roads out here are most flat and straight, and the standard Tucson day is sunshine, blue sky, and green plants. Thought it would be nice to change tires only once during 10-12K.
My experiment of the new 880 in front and the used BT20 is not working out.
The best way to describe it is that the rebound rate on the front no longer matches that on the rear. And, it feels as if the rebound rate of the front and rear are at different angles?
The closest experience I've had to this is running a springer front end on my swing arm 1961 HD chopper.
Either this Friday or next Friday, I'll ride over to SWMotosports and change the rear to the 880.
Bob, 00LT
