About to begin the disection on poor 'horse'.
Have read most if not all posts on the "old board".
Looking for a few more words of wisdom, particularly on the parts list.
Here is my list so far, feel free to fire away with critique/ commentary.
BMW parts
1.)21 21 7 670 456 Clutch Plate (D=180Mm)
2.)21 21 7 688 214 Diaphragm Spring
3.)21 21 2 332 974 Pressure Plate
4.)21 21 1 451 274 Spacer Ring
5.)21 52 2 333 433 output cylinder clutch (D=20)
6.)23 21 1 230 440 feltring
7.)23 12 2 352 156 gasket
8.)11 21 1 460 696 compression ring
9.)11 21 1 464 939 stop disk
10.)11 21 1 460 456 o-ring
11.)21 21 1 242 377 washer
12.)11 117 666 186 rear engine oil seal
13.)99 99 0 000 601 mineral oil and lithium soap (or non-BMW lube)
14.)23 12 7 656 019 Shaft Seal, Drive Shaft (17X28X7)
15.)23 12 1 340 324 Shaft Seal, Output Shaft (25X40X6)
16.)21 52 2 332 604 (X 4) gasket ring --Slave hose
17.)21 52 7 659 112 rod (L=258MM) ?? really need a new one ??
18.)21 52 2 333 450 & 451 ??? pressure hose assy?? seems like some of you replaced these
19.)??????????????? I know I must be forgetting somthing
Tools & Odds & Ends
1.) 30mm Modified Deep Socket
2.)12mm Modified Allen Wrench
3.)drive plate tool, 1" wide X 3/16" thick aluminum bar
4.)2X4, about 42" long, drilled a 1/2" hole in the center
5.)Home-made lift rig like Rhinewest uses
6.)????????? Ditto see #19 above
BMW parts
Tools & Odds & Ends
