1 - 11 of 11 Posts
My K12lt was not looked after before I got it. Not complaining, as I got it for a very good price. I have fixed most problems now, but am concerned about the state of the wires where they go into connectors. If I pull just slightly on most - they crumble!!
A. I cant find connectors to replace what needs replacing. Is there a list of part numbers?
B. What is the best way of cleaning up the wires that are left? I dont realy want to trace every wire and replace them. But the bike needs to have reliable electrics if I am going to keep it.
Discussion Starter · #3 ·
dshealey said:
Wow, never heard of that. Was the bike near the coast, with salt spray around? Overheated in storage? If the bike was in normal ambient conditions this should not be a problem.
It may be better to contact some motorcycle salvage yards and try to buy the harnesses from a crashed bike. Two here:
http://stores.ebay.com/DEEP-6-AUCTIONS_W0QQssPageNameZstrkQ3amefsQ3amesstQQtZkm
http://stores.ebay.com/Baja-Motorcycle-Parts-Center_W0QQssPageNameZstrkQ3amefsQ3amesstQQtZkm
Cheers for the links.
Previous owner used it to commute from Greece to the UK - in winter!
Dont think he ever washed it.
No harness in the UK (where I live), I am sure it would be a nightmare to fit as well
Wiring harness
I've got a generally complete wiring harness from a 2000. The only disturbances I made was to remove one of the fuse blocks and to sell off part of the rear speaker connections.
You have a PM
Hi,
I'm just down the road in Hempsted, willing to help.
Way to go
myk_edwards said:
Hi,
Way to go Myk. That's what this board is all about. :)
A temp work around could be to separate the connections, remove as much of the rotting insulating plastic as you can, use electric contact grease on the connectors, shove heat shrink over the wire, and put it all together.
Bob
Discussion Starter · #10 ·
Cheers Eatanner, I will wtrip the beast down again and bear this in mind when I reexamine the problem. I am hoping that a few old jukebox connectors will suffice (dont ask!!)
You may want to ask the service guys at your dealer. Mine has a box of old harnesses and other bits he has allowed me to pick through. The connecters themselves are hard to come by as new replacements. Some can be found through a well stocked Amp Industries supplier but often require large minimum purchases.
1 - 11 of 11 Posts
