1 - 11 of 11 Posts
OK, I liked the fit of the C3 and I have an iPhone 4 so the SRC was the logical choice. I also have a Zumo 550. So I am trying to get them all to play together. It is challanging to say the least.
Either will work with either and I can have them all connected and the iPhone steaming audio but as soon as the Zumo wants to say something all audio stops and will not restart. I'm thinking I have a software issue but I can't seem to come to grips with the fact that I may have just a sequence of who and what is paired with what.
If anyone uses an iPhone and C3 SRC with a Zumo 550...
  1. Does it work as advertised?
  2. Does the streaming audio from the iPhone get interupted by audio from the Zumo?
  3. Does it go back to streaming audio?
  4. what is paired with what?
  5. what is the sequence you used to pair?
  6. did you pair everything and leave it paired while you continued to pair?
I am going to the Zumo forums to see if there is anything there also. But it would be noce to know if someone has this working. :rolleyes:
the zumo 550 does not support A2dp stereo bluetooth protocols, It is mono only when playing music (xm, mp3 from the zumo) I do not think it will work properly the way you are trying to use it. I would try pairing the iphone to the C3 bluetooth so it can stream stereo music, the i phone itself will mute the audio when the phone is used as a phone.
Then pair the zumo 550 to the C3 as a gps only......It might work correctly that way but you will not be able to use the zumo to answer and make phone calls. Kieth
If you pair the iphone as a phone only to the zumo you will get control of the phone on your zumo screen, Use the zumo for your music source and then pair the zumo to your C3 as a headset. It will still not be stereo but it should work..
I had the same problem with a Sena,550 & droid. sold the 550 and upgraded to 665 and all works great .
I tried doing that pairing the Zumo with the SRCs and the iPhone with the SRCs and I can get everything paired but the first voice or tone from the Zumo crashes the iPhone connection. Sometimes is restores after 10 seconds of silence and sometimes it goes not connected. The latest software for the SRCs 3.0 allows an additional A2DP channel but I need that type connection from the Zumo, of course not supported.
When I look at the bluetooth settings and choose phone only I assumed that navigation only went out by the 3.5MM output jack. I have not tried a phone only BT connection.
The directions indicate that the iPhone should be paired to the Zumo first and when I do that and then pair the SRCs to the iPhone I don't get nav over the iPhone. Seems like it should work that way but obviously it doesn't for me.
Seemed like what I read here and other reports the Zumo 550 worked with the SRCs/Q4 setup but it appears the devil is in the details. I am impressed with the sound quality from the iPhone and I will remain on that channel.
I also need to initiate a SRCs connection when I power it on and it doesn't seem to sync with the iPhone. Do you have this equipment or other equipment?
I'm looking at getting a Sony BT adapter for the Zumo 3.5MM output. That supports A2DP and 10 type other connections so that is an alternate if I can't find someone that has this working natively.
I'm trying to get this to work this year on the 550 because if I like the GTL, after I ride it, I might be looking next year to upgrade and the nav that come with the factory options will allow this all to work the way I want.
For me selling the 550 involves also selling my Touratech lockable mount and together that places the 550 pretty high and difficult to sell.
What did you get for the 550?
I sold it on ebay, $456.00 and I had the BMW version.So it came with no car cradle.
Wow, thanks for the reply ... that was a pretty hefty price, I paid in the $550 originally but it wasn't a BMW version which would demand a premium for someone that had the setup or a failed unit.
That seems to be the going price for them on there 450-500. What made me decide to do it was I saw a unit (regular version) sell at $520. So I said what the heck.Started the bid @250.
So if I understand correctly, you have paired your Sena & phone to the 665? If that is the case are you able to listen to music from the 665, receive GPS instructions & take a call seamlessley?
Thats correct, You can set the priority how you want..The 665 even imports you phone book.
Thanks, sounds like a 665 is the answer.
1 - 11 of 11 Posts
