1 - 16 of 16 Posts
My turn to beg for buckets!
Using the Bucket Calculator found here, I need the following:
Qty 7 2.70
Qty 1 2.80
Qty 4 2.85
I will have the following to swap:
Qty 7 2.75 - Every single exhaust bucket was 2.75.
Qty 1 2.95
Qty 4 2.90
Note: I measured with metric feeler gauges. I converted to inches and let the program convert back to mm.
Thanks in advance!
Curious on the one going from 2.95 to 2.80 that is a pretty good jump unless you were swapping others around.
I have 2 - 2.70s but none of the rest. Most of what I have are 2.95 2.9 and 2.75.
John,
The only 2.95 is going to 2.90.
Did that attachment open ok? It doesn't for me.
Here it is in pdf.
Yes it did not open as a populated file. PDF was good. But typically if the clearance is 0.006 it is good and 0.010 it is good. These calculators cause a lot additional bucket changes just to get the reading in the middle which is not necessary as they don't really change that much over time. You can see how mine has gone from new to the 76 K check as a go by. Red indicates a bucket change.
I only know what I've read here.
I wasn't thrilled at the prospect of changing all those buckets, but seems like a good preventative move, since they are all at the low limit, and reportedly only get tighter.
I figured I'd do it once, and hopefully never again.
No problem. How many miles on the old girl? Hopefully more will chime in on what buckets they have available.
Enjoy The Ride
I guess I just don't understand why anyone would swap a good thin bucket for a useless thick bucket.
Bike is a 2000 with 132,000 miles.
Previous owner swapped in a 2002 engine with 40,000 miles.
I've put less than 1,000 on so far.
So I'm going with 41,000 miles. :)
One man's thick is another man's thin...:p
I was just thinking about the swaps I have done & now everything I have is 2.90 or thicker & I can't see ever needing the buckets I have.
Owning an LT adds new meaning to "bucket list."
:histerica
Discussion Starter #12
Dave, I was thinking the same thing.
I ordered the buckets today from Max BMW.
Probably be a week.
Thanks for the responses everybody.
Man, timing is everything, right? I did my valve check a few hours after you posted this and, after pulling the cams, realize I have (6) 2.85 buckets that I don't need. If you want to remove them from your order, I will send them to you.
GB
Discussion Starter #14
GB
George, that would be great! Thanks.
I emailed Drew at MAX BMW. I will call them if they don't respond.
Do I have any buckets you need?
I have the following to swap:
Qty 7 2.75
Qty 1 2.95
Qty 4 2.90
I'll PM you my shipping info if this works out.
Thanks again! :dance:
Yes it did not open as a populated file. PDF was good. But typically if the clearance is 0.006 it is good and 0.010 it is good. These calculators cause a lot additional bucket changes just to get the reading in the middle which is not necessary as they don't really change that much over time...
Unless you're lazy, or have other factors which delay doing proper maintenance, (like a suitable place to work). Of the 16 valves on my '06, (with 91,000 on the clock), I need to make 13 changes. However, all but one of them are just one step, and that one is two. It's been 50K since the last change, but only 40K since the last check.
GB
I'm helping a buddy with his valve adjustment. After getting a line on most of the needed buckets we are still going to be in need of
(4) 2.70's
If anyone has any of those laying around they want to swap let me know.
1 - 16 of 16 Posts
