Hi guys.
Have a 1999 K1200LT.
Recently the small upper left hand corner of the black rear luggage handle broke off.
That of course make impossible to open the case.
I removed the case and used layers of Crazy Glue to glue it back together.
Of course I could not remove the entire handle mechanism (which would've made things easier) since it is riveted to the case.
After I let the glue dry for at least 24 hrs, I put a layer of duct tape then a layer of Metal tape to give it strength. It seems to work just fine.
I re-installed the case on the bike. That day I carried a tape deck in the case and I guess it stressed the handle which broke again in the same place.
I guess I can glue it back again.
Any advice on what to do, should I use something else besides Crazy Glue that maybe stronger?
And what is the cost to replace the handle? I don't/can't spend a lot of money on this so the cheaper the better.
And is there an easy way to remove these rivets if I want to replace the handle or to make it easier to do the repairs ?
I am in San Jose, California if there is someone close to my area who have experience in this and wants to help me.
Thank you all,
AJ
Thank you all,
AJ
