Hi,
On my way back home tonight, I noticed that when I was braking with the right front lever, the brake light did not turn on while it was working perfecty with the foot brake pedal.
Once in my garage, it was working fine again using the front or the rear brake. I suspect a switch located in the right handlebar. What do you think ? If it's a problem with the switch, is it difficult to check and to change ? Can anyone post a pic/draw of it ?
Thanks a lot for your help,
Pierre-Alain
Pierre-Alain
