Hello All,
I'm fairly new to K1200LT ownership. I live in the UK and own a Honda Blackbird, a Honda CBX1000 and a Honda Pan European 1100.
So, mainly Hondas.
My LT is a 2001 model with 25000 miles on it. When I bought it, the ABS light and brake failure lights where flashing alternatively. I was told that the battery on the bike was not the correct one and this was causing the lights to flash due to not enough power coming from the battery.
I have used the bike a few times to get to work, not yet changed the battery. The brake failure and ABS lights then began to flash very quickly and I lost servo assistance, making braking somewhat interesting, or non existant depending on how you look at it.
I pulled over, switched off, switched on again and had brakes again, though the brake warning lights where flashing very quickly.
I got it ome, turned it off and left it for a day or two. When I came to ride it again, I had the alternate abs and brake failure lights then after a few more miles I had the quick flashing abs and brake failure lights and no brakes again, until I switched off.
Help. I have no idea where to start, well the battery but then after that, I have no idea. Is this common?
So, mainly Hondas.
