Has anyone used the Motion Pro Mini Bleeder? I just saw it advertised on the back page of my June 2012 MCN magazine and it looks like a speed bleeder for those of use who don't really want or need speed bleeders. Not sure this is much easier than using the bleeder bag, but it looks like it might make things a touch quicker when working alone. Not sure it would fit into the confines around the LT ABS unit though.
Does anyone know if a clamp is available to replace the tie wrap on the rear (small) end of the final drive boot. Mine weeps oil and makes a mess on the FD. I would like to find a clamp like that on the front of the boot to see if it would seal a little better.
I looked at the fiche at Bob's and the diagram shows two options for the front clamp (item #13): one appears to be the metal strap and the other a plastic strap. However, it appears that only the plastic strap is available for the rear (small) end of the boot (item #11).
Does anyone know if a metal strap of the appropriate size is available for the small end of the boot?
