I've always wanted a BMW motorcycle, and I finally picked one up yesterday. It's a 1999 K1200LT with 105k miles. It had been sitting the last couple of years, but the owner would start it every couple of weeks. It finally reached a point where it would turn over, but not fire. He traced it to -at least- bad wiring in the tank for the fuel pump. He was physically unable to continue work on the bike (has a shoulder that needs surgery) and he decided to sell it cheap, in hopes that it would get fixed, rather than sending it to a junkyard.
Here is the fuel pump assembly removed from the tank:
I've been reading up in the forum here on the common fuel pump assembly issues, and it seems this one has them all. The wiring in the tank was horribly deteriorated.
And the contacts at the flange/bulkhead passthrough are broken off:
I bench-tested the pump and it is not running at all - it makes no attempt to run when power is applied.
So, I have ordered a new pump and filter. Based on other posts here, I decided on this one https://www.amazon.com/dp/B07RSCVX1X . It includes the strainer and new fuel filter, too, which certainly need to be changed, based on the condition inside the tank.
I also ordered the nylon in-tank fuel line ( Flexible In-Tank Fuel Hose Kit ) and fuel pump assembly "tune-up" kit ( New Fuel Pump ) from beemerboneyard. The previous owner already had the appropriate in-tank repair wires.
So, now I need to figure out how to repair the wire contacts at the assembly flange ("bulkhead). There may be enough left where I could solder terminals onto what is left. Or, I could try and melt new contacts through that plastic. BUT, I was intrigued by these: Bulkhead Stud, 6mm Delron/Viton, SS (BHS-6MSS): Bulkhead Connectors . Fitting 2 of them through the flange would seem to do the trick, and then I could re-use the bike side wires+connector. Has anyone tried those?
Thanks for any advice! I already found the .pdf of the service manual online, so that will be handy to have.
Oh, and anyone have a recommendation for an adapter to use to lift the bike on a 2-post lift (I've got one in the shop garage)? It might be helpful for certain maintenance/repair tasks.
Here's a pic of the bike (it came pre-disassembled)...
