1 - 14 of 14 Posts
2017 R1200RT
Hi, I'm a new owner of an 06 LT. First time BMW owner and so far I love the bike.
The bike started something a week back (after a cold temperature outside of around 14 degrees). I keep it under a cover in a carport.
Both cooling fans now come on when I switch it on to crank it. I have pulled the fuse under the seat and they go off, but can't find anything wrong.
Is it possible that a wire is shorted somewhere? (I have seen evidence of mice around the carport). I checked the two connections on the bottom / front of the motor ( I think these are the temp sensors) and everything looked okay there too. The shop tells me the relays are under the tank and that that is most likely not the problem.
I have the Clymer manual and studied the wiring diagrams last week and it appears that the relay is allowing power to the fuse panel as I mentioned. The bike only has 7100 miles on it.
I took it for a 20 minute ride this afternoon and the fans ran the whole time.
If you turn the kill switch to the Off position, they do not run or if you pull the fuse under the seat they do not run. Other than that, they run while switched on.
Any ideas on other things I can check?
Sammy
Sounds like you may have a bad engine temperature switch. Its located underneath the engine, covered by a small rubber boot. I don't remember if you need to remove the lower cowling to get to it. Your Clymers will have pix.
I hates thoses meeces to pieces. :D
Start looking for the little boogers and don't ride with both fans going - you'll never get the engine anywhere close to operating temperature.
I have *heard* that using a potato peeler and shaving off pieces of Irish Spring soap - then scattering around the floor under your bike - will keep them away. Apparently you need to use the REAL brand and not a knockoff and renew monthly.
Mothballs inside of socks stuffed inside the fairing at several places WILL work, but they are darned expensive and sublimate rapidly.
Welcome to the forum Sammy. Sorry I can't help with your fan problem, but sounds like Ron has some good suggestions to keep the mice away. I still think a big hungry cat is one of the best things, but you may have a problem keeping the cat in the car port. Best of luck with finding the problem.
Just feed the mice! :histerica
One other thought - although kind of strange - could cold temperatures have caused it?
Hmmmm...... (stroking chin)
Sammy,
Check to make sure you have the temp sensor (#15 in the pic below) connected at both ends.
If that is connected, then check the wire connector on the upper left side of your bike under your seat.....you'll have to take off your left side battery access panel to get to it.....
Here's an online manual to help until you get yourself a Clymers (strongly recommended). ....look at page 17.8 for radiator stuff....troubleshooting begins on 17.12.....
Good luck! :)
garage cat !
That one only drives the temperature gage. The one at the back of the cylinder head is the one that feeds the ECU which, in turn, drives the fan relays. BlauBeeMr has it correct.
2017 R1200RT
Thanks everyone for the replies. I've been following along on here for a few months prior to my purchase. I will look for that temp sensor this weekend. I found the one on the front of the engine (front of bike), but it looks like the one I need to check is towards the rear of the bike (in front of the rear tire).
Have a great day!
Sammy
Thanks for setting me straight on this one, John. I have to go back and check my own. I'm guessing that this sensor is pretty much buried on the back side of the engine. Does anyone have any photos showing the location of this sensor?
Bob
Enjoy The Ride
I don't have a picture but it is on the rear of the cylinder head near the ignition coil.
2017 R1200RT
Discussion Starter #12
Ok, I found the problem. The mouse bit through the wire coming off the back of the engine temp sensor towards the rear of the engine. I have about 4 inches of wire on the sensor and the remaining hanging from the battery compartment. Not sure how to proceed. The casing has two wires in it, a yellow one and a brown one. I can't seem to get the wire or sensor off of the engine so I can splice the two back together. Does anyone know how to remove either the wire from the sensor or the sensor from the engine. I removed the lower left faring so I can see the wire, but it's behind a square black housing that has a horizontal mounting bolt on the top (out of reach) and the bottom. The bolts on this housing run front to back on the motorcycle if that helps identify it. I think if that housing were removed, I could get in there to work.
Thoughts, ideas? I really appreciate the insight from this group.
Sammy
I believe the sensor unscrews like a spark plug, but drain the anti-freeze before you take it out. Beyond that all you need is a couple of jumpers, solder, shrink wrap, and some dead mice.
That "BlackBox" is the coil. You can swing it out of the way and disconnect the other end of the cable and that should give you room to work.
1 - 14 of 14 Posts
